12VoltInstalls
life passes by too quickly to not live in freedom
In a recent thread the idea of ‘stealth’ or ‘guerrilla solar’ grid tie microinverters came up. Since I’d been thinking about that it prompted me to purchase one of these units and use it with some spare panels.
Since then, however, I have been plagued with the fact that I have 800W of panels running off grid and on sunny days have plenty of excess. (I am not grid tied, merely using a 120V/1.2A power supply that holds me at 12.8V at up to 10A for the dark/winter months. It’s doing well.)
Since I have 800W solar that is excess on sunny days and I could go 1200W easily if I chose, I started wondering how to do the same thing as the low-buck micro inverter and use my existing panels. I’m frustrated to find an all in one hybrid that will backfired the grid and work with a 12V system, however.
The MPP 1210 does everything I’d need except it doesn’t support backfeeding the grid (so grid-down disconnect doesn’t matter because of this) and it seems low on solar input capacity/watts unless I’m reading that wrong.
Is there any economical unit that:
- supports 12V battery system
- will grid-tie with grid-down disconnect
- offer grid-charging at battery low voltage
- will also function fine off-grid
Since the 1200W Inverter I use now is sufficient I’m unconcerned with the inverter specs other than wanting to direct up to 800 watts back to my friend’s consumption when the sun provides. They use a lot of electricity so I’m expecting to not ever exceed their grid demand.
I’m setup with lots of 12V and therefore do not to go 24V. This isn’t a necessity project, it’s just entertaining and practical.
Outside of the Schneider or other top-shelf equipment does anything exist to do this? I’m thinking not at this point but I’ve learned a lot the last day or so.
