ruralsolar
So I have a small shed that really all I need is lighting for, inside and possibly motion sensing outside. I have 240Watt panel, 24AH LiFePo4 (without cold temp sensor) that was a gift and a solar charge controller that supports Li chemistry. I know I'll need a small heater pad to keep the battery from freezing, what I'm debating is the box to house this. I was thinking of buying something waterproof (even tho it'll be inside) and insulating that but then thought, is it nuts to use a 30qt cooler? Drill a couple holes for wire glands for the cables and be done with it? I can get a cooler that size for ~$30, 12v pad heaters for ~$20, controller for those ~$10. Seems like a no brainer versus buying or building something more purpose built?
