Goal is a 564 (or whatever is available at the time) bank. Comprised of 16 cells in a 8s 2p configuration.
Is there a correct way to manage this system in regarding to 1 or 2 BMS being used?
I was initially going to with 2 Daly 100a 8s BMS's but then was encouraged to use the same BMS but on the entire bank, from what I gather that meant not every individual battery would have a wire to it, rather making the 16 cells into 8 cells monitoring paralleled pairs. If only one BMS of the same size is used vs two wouldn't that also reduce my available current draw and charge rate?
Not sure if that makes sense so if I need to clarify please advise, but I'm sure someone has done this or at least understands what I'm trying to say.
Lastly once that is resolved I'm searching for the most user friendly BMS for this.
I pulled these two pictures from a similar thread, on the first photo, C and D make the most sense for me as I want to stick this on a cart and have it be somewhat mobile, second photo is how I was planning on doing this before I knew one BMS was an option, but ultimately looking for the best and safest way to do this.
Appreciate any and all advice.
