ruralsolar
I have a few other posts but I think I'm narrowed down to what I need to finally go to the bank and get my funding! I'm looking for a ~16kw DC power solar system linked to a sol-ark 15k.
- Quantity 36 ~450W panels - what panels exactly will depend on what is available when I'm able to actually purchase them. Leaning towards bi-facial but only if price is right
- Quantity 1 Sol-Ark 15k. Will do battery "later" as NYSEG is one for one with net metering so battery is only needed for when grid is down.
- Sinclair Designs Season Adjustable 36 Panel - Maybe "overkill" to do season adjust but I'd rather have the option than wish I had it later.
- Sub-Panel for "before" sol-ark to take high amperage/draw loads. Grid --> electric meter panel --> High Loads Panel --> Sol-ark --> "Main" house panel
- Quantity 2 IMO Disconnects to be mounted at the racking. Assuming 4 Series of strings combined to 2 parallel strings (9 panels on series, 18 on parallel). Should keep me below the 500V DC VOC and below the 26amp rating per MPPT on the sol-ark while leaving me with one more MPPT for potential future addition.
- Array will be ~150-175ft wire run from where sol-ark will be located in basement of home
- Located in upstate NY, NREL PVWatts says I should get ~19,000 KWH per year at 32.5 degrees, so if I do my diligence of seasonal adjust that should go up marginally
- Permit plans and schematics from a reputable and previously mentioned firm on this site (Have a few on the list so far)
