Since the Overkill BMS is rated at 100A @ 48V and you have three banks = 3 BMSs = 300A @ 48VDC. The math is 48V -> 120V. A=W/V. Since you're dealing with 300 x 48 = 14,400 Watts. Then... 14,400 / 120 = 120A. Less 10% that the inverter gets as payment for doing it's job - you get roughly 108 Amps @ 120V - be safe and say 100A. Now things get squishy... The BMS will overperform for a short while (not spec'd on this particular BMS - maybe 5-20 secs) long enough to start an electric motor, but the leads on the BMS are just a couple 8ga wires. You will have 6 of them with 3 BMSs, but my guess is they will warm up even at an amperage lower than your 100.
