I built my first 18650 battery pack and have a few questions because it's not working right. Was going to use it for 12v items,110v inverter, and some USB devices like cameras around the cameras. I tested the battery on my inverter but the voltage was too high for the inverter input. My 4s battery pack at 16.8 volts so I plugged it into a group of fans to use up some power. I got it down to 15v but now it won't send any power to the inverter. When connected to the inverter it shows like 2v. I'm thinking the BMS is turning off the power due to low voltage. Any ideas? Do I need a boost controller to bring down the voltage? The plan was to charge it only to 14.8 using my solar controller.
This is the BMS I bought Protection Board 4S 30A 14.8V PCB BMS 18650 Li-ion Lithium Battery Protection Board with Balance
I'm kinda thinking of taking it apart and building two 3s batteries instead but was thinking the 4s would be better at running an inverter.
