Frank in Thailand
making mistakes so you don't have to...
Google :
Can a grid-tie inverter be connected to batteries?
In an AC coupled system, the grid-tied inverter is paired to an off-grid inverter and battery bank. The off-grid inverter provides a second power source, which effectively tricks the grid-tied inverter into staying online. This allows you to charge your batteries and run essential appliances during a power outage
Ok, this is "old" .... Yes?
Already a smart company that made the combination??
Post in thread 'Grid tie solar with backup' https://diysolarforum.com/threads/grid-tie-solar-with-backup.62948/post-783764
AKA AC-Coupling.
Trouble is the way it's connected.
Grid tied gets the wave& voltage information from the grid, matches it, and increase the voltage a bit, so the power from the grid tied is used first.
It's easy, you can simply plug in the power socket, and it will provide electricity to that group of the house.
Absolutely easy, add on, additional power.
On/Off grid (or "hybrid") they don't "add". (AC - Coupling)
They sit in between.
All the grid power must go via that unit.
Makes sense and all, safety reasons.
But...
Say you want / have 1kw solar..
Plug in grid tied= 1 kw unit, 3 x 345w solar, done.
If your power group is able to provide 3500 watt, you get 1000 from the grid tied, and 2500 from the grid.
The on/off grid (& hybrid )
Still 1 kw.
Still 3 x 345w solar
Your power group is able to provide 3500 watt
You buy 1000 watt unit.
Not going to work.
Well... You can use the 1000 watt.
But when you want to use the 3500...
Overload, error, beep, stop.
It sits in between, and logically, pushing 3500 watt through a 1000watt unit...
As default... Should not work.
2 possible solutions:
- buy the 3500 watt unit
- make it capable of both, yet limited to 1000W during blackout.
Victron calls it the pass through amperage.
Some other brands start to adapt this.
What grid tied units are out there that can be used as backup (so with 48v battery) and do provide roughly 3* their rated output as pass through amperage???
I do see several solutions, yet they all limit the passthrough to the rated capacity..
We really like to have 3-4 times the pass through capacity then the rating of the unit.
As usually.. just adding a bit and using a bit.
AKA AC-Coupling.
But...
Still 1 kw.
Not going to work.
