villa frontera
Hi All
I have a solar hot water panel roof mounted and I have a 2.2amp pump installed on the circuit pipes to the floor mounted storage cylinder.
I would like to run this pump either from a pv panel or via a 220v to 12v transformer.
if I run it from a panel as the sun goes down the pump will stop which is good. If I run it via a transformer then it will need to be controlled by a timer. If I go down the panel route what size panel is suitable for this 12v 2.2 amp / 26.4 watts pump?
your experienced answers will be appreciated
