Not sure if this is the right spot but here it is.
I am in the planning stages of bringing in 2 - 20 foot shipping containers to my property. One will be for storage with lights and a couple of outlets. The second will be for a small wood shop, most likely the largest load will be some type of woodworking tool and a small dust collection system operating at the same time.
I have room to put in as much as 6 to 8kw of solar if needed. Initially 2 to 4kw. Because of the distance to my breaker box on the house, how full the breaker box is and the existing grid tie solar my intention is to keep the containers in an off grid scenario. Plus it is a nice little project.
I have not decided how far apart the containers will be. They could just be side by side. Or up to 20 feet apart. The initial thought would be to put all solar related equipment in the storage unit. This would be the the inverter, batteries, main breaker box, etc. Then run the wire and have a sub panel in the workshop container. My purpose for doing it this way is to keep all solar related equipment free of dust and other debris from the wood shop.
I have built 3 -12 volt solar systems for a RV vehicles, two 30 amp and one 50 amp systems, so I have the basics of how things work and tie together, but they are a different environment that a fixed off grid environment. I am thinking of running 48 volt battery(s).
I don’t have all wood working equipment at this time so I don’t have a total load requirement so sizing is up in the air at the moment. But what I need help with is what type of inverter equipment I should use. An all in one would be nice, but I am unfamiliar with that type at this point in the planning.
At this time I only have a few tools mostly hand power tools, I have not bought containers, big power tools or solar equipment. I do however have a large C-Band satellite dish that I would like to repurpose as a tracking solar panel system.
Keep in mind that the containers are 8’ x 20’ so there will not be a lot of larger equipment. If anyone has a good workshop layout that would also be helpful.
Any thoughts on type of solar equipment I should look at, size would be good even though I don’t have a total load at this time. I am sure those that have built shops can provide a reasonable solution.
