Hedges
I See Electromagnetic Fields!
- Mar 28, 2020
- 21,900
If voltage-output CT, get four 200A (or higher) CT.
Install around L1 and L2 of each box.
Read label - is it something like 300 mV for 200A? Or does it output current?
If voltage, I think you can just splice the two L1 CT in series and the two L2 in series. That would put out 600 mV for 400A.
But maybe that is too much for whatever amplifier gain stage.
So probably just connect in parallel. (either way, get polarity correct.) I think it will then read 300 mV for 400A.
If it is current output not voltage, in parallel would deliver twice the current for twice the utility current.
Maybe four 400A CT would be the way to go. Two, 400A current-output CT in parallel each carrying 200A should give same reading as one 400A CT carrying 400A.
See if you can read the labels/specs of the CT before buying and using them.
