Hello Folks!
I have my eyes on 4pcs Lifepo4 12V Aux battery for my vehicle. Small form factor is key and I see some 240Ah seem to exist on Aliexpress in dimensions 175*48*185mm (w*d*h, height being 170mm + 15mm stud) which would be ideal for me.
Is that a legitimate size for this capacity? If not, that is the typical capacity for this size?
The density of those 240Ah seems too good to be true at about 160mAh/cm3, 45% better than your typical 300Ah (~175*72*200mm) at about 110mAh/cm3!
Also, I couldn't find out who the manufacturer is which is probably not a good sign...
FYI, I have seens those in a few stores for about $360US for 4pcs.
Any insight on this would be much appreciated!
Cheers!
Cheers!
