24v batteries to run 48v motor
James Mc
Hi All, I'm changing the motors in my boat and trying to figure out if I can use my existing batteries. I was using 2 x 24v 2.2kw motors with a 24v 100ah LiFePO4 bank on one and a 24v 150ah bank on the other. The new motors I'm putting in are 48v 3kw. So my question is can I utilize these banks maybe through a bump converter or something?
Putting unmatched batteries into series doesn't work well. They won't charge and discharge together, so the combination won't allow you to access the full capacity of the two batteries.
That said, they'll have the same problem in parallel.
In both cases, you might get something less that 100Ah out of the combination.
As for bump converters, 24V->48V converters exist, but you'll need one that can handle 60+ amps. If there are any on the market, they will be large, heavy, and expensive.
buy one more of the 100Ah and one more 150Ah,
Pair the 100's together, pair the 150's together. - they will not charge and discharge evenly, maybe close enough for your set up?
Sell the 24v batteries and motors together? - {or repurpose the 24v batteries for a mobile unit with a MPP 2724}
Buy matched 48v 100A batteries and easier to keep them all balanced.
Yep jdege.. just had a look at converters cheap as chips up to 30 amps but nothing much over that and 30amps would be fine to run the motor at 80 or 90 percent which would be fine but they wouldn't handle the surge to start them.
Thanks for your thoughts OffGrid. Looks like there are no good budget options. I'll have to just spend the cash on a new bank and looking at what is available in Australia it will have to be 16 x 280ah cells (cheap at $160AU each). Up side is I can rip the top off my tenders outboard and utilize the 24v stuff to convert it to electric.
Absoluetly, but select a converter that is 2-3x bigger than the continuous load. That would be standard practice with a motor controller. You can put a few smaller ones in parallel if you can't find a single one large enough.
Where would you get the 280 ah cells from?
