Hi guys. Just joined here. We have an off grid vacation place with a Schneider Conext XW5548 system. Been using Trojan L16 325ah for about six years. Time for new batteries and I'm sick of lead acid.
I'm temped to buy these for the simplicity, warranty and security of ordering from a vendor in the USA but I feel I could save a ton of money ordering from Deligreen.
I don't see myself using more than 30 - 40% of the 280ah capacity even in the winter. Much less in the summer. Then again I am used to amp hours being at the 20 hour rate so I'm not sure what 280ah means with LifeP04.
If I order from Deligreen what BMS do you guys suggest? I would like a good one that balances the cells and cuts power if the voltage drops past a set point. Is it really necessary to compress the cells? The vendor I listed above doesn't think so. He provides adhesive tape to assemble the pack.
Thanks for any advice!
48V 14.3kwh LiFePO4 battery system with BMS (280ah)
www.treelinepowersystems.com
