Not really. Let's do a little napkin math...
Right now you have 4x 180w panels which could produce 720w of power. Your SCC is a 40a unit at 14.4v which maxes out at 576w of power. 720w - 576w = 144w of power your system could produce but you can't use. In an average of 4 hours of good sunlight that's 144*4=576Wh of power sitting on the table, almost half of a 100Ah battery. If you spent the money on 2 more 180w panels you might see another 40w or so until that 40a limit started becoming a factor which for a couple hours of low light means maybe 120wh of extra power from those 2 180w panels.
Now, unless you're getting those panels super cheap, you can spend
$240 on a 60a EPEver unit which would cap out at 60a * 14.4v = 864w of power from the panels you already have. That's your full 720w of panel, and over a 4 hour "Good Sun" period gets you 720w * 4hr = 2880Wh per day to your batteries, or almost 300Ah of battery. That right there is almost like getting a whole free panel.
In the future, and finances permitting, you could add in another pair of panels and get 180w * 6 = 1080w / 14.4v = 75a of charging which would max out your new SCC but also pick up that earlier morning and later day sun because of the higher operating voltages of the 3s strings.
Given the choice, and it does matter how much the panels cost, I'd spend the money on a bigger SCC for 2880Wh of production than another pair of panels that are only going to get you very few watts and then be useless most of the day.
But that's just me. Early morning and late evening I've seen panels that just barely reach working voltage still not have enough to create any meaningful amperage.
Always beginner's mistakes I made !!!
At least you can come here and ask and learn, I started before this forum existed and have spent a LOT of money and headache trying to figure this stuff all out. ?
