hello,
My first Multiplus II 5000/70-50 , is already connected to 6kw PV and a 13kwh LPF battery pack, at home. With a AC output 1 limited to 22A.
ESS assistant used with 100W grid feedin.
OffGrid is not my fisrt goal.
And I want to connect a second Multiplus II 3000/35-32, to extand my AC Loads capability with 13A more (as powerassist is able).
So "AC out 1" will be 22A + 13A (assist).
My first goal was a serie configuration, with 2nd inverter as a generator (as offgridgarage use case), and relay command start/stop.
1. But what about ESS configuration ?
2. Another design is possible , in parallel ? Considering same model and firmware , but different power capabilities ?
Thanks for our advice.
PS: I'm a OffGridgarage viewer
