3rd party power supply on a Bluetti?
If it is the supply I am thinking of, it has an output voltage of 52v. Should be perfect for fast charging the unit.
Ahh that one is a bit overkill, but the variability might come in handy.
The steady voltage ones should do fine.
Ahh that one is a bit overkill, but the variability might come in handy. The steady voltage ones should do fine.
Thanks. I also have a bad habit of, after hours of searching, finally stumbling into the answer after I make a forum post. I found a YouTube review that uses a similar power supply. ?‍♂️
