Daddy Tanuki
Solar Wizard
you are treating it like a DIY pack with a BMS. the batteries, if they can be used in series or in parallel, (depends upon maker and internal BMS) will self level between 12 volt batteries under normal use, if they are not its a physical buss bar/connection issue.I’m not sure I understand your remarks. I also use premade batteries with their own internal bms. The internal bms of a battery does nothing to balance each battery that is in a series string. Each individual battery must be at the same state of charge as the others for the 48v pack to produce its full ah rating. The individual bms of the battery will not balance the batteries in relation to each other only the cells inside the battery that are monitored by the bms and in some cases (it happened to me) the internal bms doesn’t even balance the internal cells of the battery. Perhaps you did not catch that we were discussing a battery bank that is a series configuration?
Which is what you basically said.
When you go into trying to balance 4 /12 volt batteries that are wired in series for 48 that's when you went off the deep end. I suppose somebody sells a balancer for this but being that you can tie any normal four 12 volt batteries into series and not have an issue I would call it a non problem... he has a connection issue, or his batteries internal BMS cannot handle being wired into series.
get with the program is a Marine Corp saying designed to F with your head. Get with the Program
