tracker1
I am working to replaced the lead acid batteries in my 48V Club Car with LiFePO4 for two purposes. One, to power the golf cart that I use for chores around my yard and for occasional short street trips for the grand kids. Second, as possible back-up storage for my house when the power goes off.
I ordered four Dr Prepare 12v 100Ah from Amazon for $819 that each have a complete BMS system and are rated at 1280Wh. I also ordered an Ocell 48v Lithium battery charger that has a rated output of 58.4 Volt /5 Amp. I plan to buy some solar panels to charge the batteries in the future and will need some help with that down the road.
First, do you think the four batteries hooked up in series will provide enough power and amps to run the cart?
My second question concerns charging. I'm concerned if using a 48v charger will be a problem. I read another post on this site concerning charging two LiFePO4 12v batteries, and the consensus was to initially use a 12v charger to balance each battery to get the same SOC, then hook them in parallel to further equalize both batteries, then after putting them in series use a 24v charger for normal maintenance charging. Would that same process work for the 4 LiFePO4 batteries I'm buying? I asked the manufacturer of the charger if they thought it would work. They said no, here is their answer: Our engineering team does not recommend you to operate in this way,There is a possibility that the MOS and TVS tubes of the battery module may be damaged, which could in turn damage the charger.
I have also asked the battery seller if they recommend using a single 48v charger but have not heard back. I'm also worried what would happen when using the 48v charger and one of the batteries hit full charge first, would that batteries BMS stop the charge for all the batteries, or would it just divert the charging voltage to the other 3 batteries and possibly send too much voltage?
