How bad is it to double up two lugs on one post of a buss bar? I bought 4 post buss bars. I have 4 batteries wiring in parallel. I also need the cable going downstream to the t-class fuse, then cutoff switch, then Lynx Power-in, then Multiplus. Will there be any negative effect if one post has a lug from the battery and a lug for that downstream cable? Or is it better to return the buss bars and find 5 or 6 stud bars? When ordered I was just thinking of the 4 batteries.
