solarHandyman
- Jul 22, 2020
- 55
I rebuilt an older Midnight Solar combiner box and I was pleased with how it turned out. As my peak current is under 30 amps I like using recycled bus bars or ground bar kits from the store with polyester standoffs from Amazon rather than paying extra for oversized bus bars branded for solar. The old breakers were single pole LittleFuse breakers with 10 amp fuses. The new breakers are double pole Cbi 10 amp breakers. The Cbi breakers are smaller which allowed four double pole to fit. To save space inside the box I put the equipment ground on the outside utilizing an unused aluminum ground lug for a solar panel. I bonded the equipment ground to the solar array and the ground rod at the array with a white 10 awg stranded PV wire. (I have a rod at each array and one for the 48v battery rack on top of the two for the main panel in my house, all bonded). Red and black are my positive and negative PV conductors. The MC4 connectors are from Amazon. I'll be adding clear roofing sealant on the MC4 connectors for extra waterproofing, and more importantly to prevent pullout as this is a problem I've had in the past with inexpensive solar connectors.
