My diagram and plans for creating a LiFePo4 12V 4 x 100Ah battery bank.
I am choosing a flexible buss bar setup. I thought about a solid copper buss bar but I am concerned about all the terminal connections not being perfectly level and thus creating poor/stressed contacts.
This battery bank will feed a 1000W Renogy inverter. I am not sure what fuse size I should use in the positive to the inverter.
The 100A terminal fuses I picked are based on something I read or heard where you want to avoid dumping huge amperage into a faulty battery in the chain. There is a complication I see with these batteries since they can only accept 50A input.
I have chosen the diagonal charge/discharge layout.
Click on the thumbnail to expand.
