Azycray
System background: Just finished assembly yesterday, Growatt 5k inverter w/transformer to split phase, 4 Renegy 320w panels and 4 LiTime 12v 230ah in series. The issue that prompted this was a microwave and a toaster oven running at the same time, before dinner so no direct sun anymore. This morning I tested the microwave at 1600 watts and the toaster at 1500, these both running have never been an issue on grid with a 20 amp breaker. But when I do the math, they should be pulling 25 amps, so I can't explain that. Running on solar from batteries it didn't pop the breaker in the Reliance transfer switch, it popped the 50 amp DC breaker (cheap and undersized). Doing research this morning I find out I should be using a 62.5amp breaker using a .25 surge factor. Also I should be using a class T fuse instead? I get on the horn with Sig Solar and speak with "technical support", he asks what I'm using and I tell him the Growatt 5k and he puts me on hold to research and comes back to tell me I need a 200amp breaker. I said you don't even know what batteries I'm using, he made an assumption. I told him I have 4 12v in series (which they are rated for) and rated at 200 amps continuous discharge. He puts me on hold again and come back with the same recommendation. I told him that in 4S the continuous discharge would drop to 50 amps, correct me if I'm wrong. He stuck to his recommendation so I thanked him for his "help". That brought me here, in the recent past coming here I know there is a wealth of knowledge and this one should be fairly easy to solve. The choice is a class T fuse, suggested rating of 62.5 amps so I'm guessing a 60 will work but is a 70amp too large? Or, I'm also looking at a Blue Sea Systems 60 breaker. I realize I have a lot more potential to add more panels and batteries but this is what I have right now. I'm looking for oppinions, what should I use? Thanks in advance, RJ
