I really want to install LFP batteries in my RV, looking to start with battery bank, then configure to charge with the alternator instead of the generator. Finally installing a fixed inverter system.
I found these 500AH prismatic cells on alibaba, they would fit perfect where my original lead acid batteries now sit. Is buying these from China somewhat safe or really risky? I’ve asked them if these are new or used, they said new but have been sitting in the wear house for a year? Asked if they are grade A and they said yes.
I expect I would assemble with a 250 amp BMS from Daly, planning on installing a 2000 watt inverter. Want to set it up for charging with the RV alternator, it has a 185 Amp output, but I could get a higher output but I want to install a Renogy Dc Dc 50amp charger with Mppt solar, I’ll install panels later but 50 amps should charge this OK.
