Thanks ?Battery Communication Failure is your problem.
I did that to test the inverter and is giving me 240v so I thank is the battery communication. I try to use a my windows pc to update the firmware but got stuck on “Address 0 read remote measurement information failed!” In the eg4Set battery type to lead acid and confirm the inverter is working correctly.
Then you can go down the comms path if you are feeling brave !!!
not yet still working on it. I will update here if I find anything.Did you ever figure this out? I just fired up my 6k and have the same issue. Based on the documentation this should be configurable in UI under "Common Setting", but it is nowhere to be seen.
As for the 6K it the battery communication problem. I set it to lead acid and confirm the inverter and it did gave me 240v so the inverter is working. I need to update the battery framework for to communicate and I’m stilling try to figure that out.Not
I have a ticket in to Sig Solar with a reference to this thread as well as all my troubleshooting steps. I will reply when they get back to me as well! I believe this is a problem with their UI - I have never seen the option to configure battery type. In fact, I dont even see the "common settings" the documentation references in the interface.As for the 6K it the battery communication problem. I set it to lead acid and confirm the inverter and it did gave me 240v so the inverter is working. I need to update the battery framework for to communicate and I’m stilling try to figure that out.
Turn out I can’t update because they sent me the wrong USB cable for the eg4 battery. Make sure you get the right cable for your battery to computer. That my problem.Did you ever solve this? Same issue happening here...
