So I've been reading all afternoon and getting more and more confused as to series / parallel wiring my panels and how to fuse.
Here is what I have:
6x x 100w renogy panels (4x 100 watt panels from this kit https://www.renogy.com/400-watt-12-volt-solar-rv-kit/ - upgraded to better controller below - 1x 100w new matching panel and re-using 1x 100w renogy panel that is 3 years old from existing setup)
renogy 40a li rover mppt controller (I know it may be limiting when we rarely get a full 600w)
210 ah 12v agm battery from old system I'm upgrading from (will replace with 200-300ah lithium self heating at some point - i think - seeing if prices come down)
50 amp breaker for between controller and battery
All to be flat mounted on roof of our small Provan Tiger CX RV. Off grid RV use. Want to charge e-bike batteries and run RV systems mainly fridge, lights and heater. We camp year around in shaded areas sometimes and do travel in winter regularly - usually trying to stay in areas above 20f overnight lows and above freezing daytime (Rv only 3-season built). We live on continental divide in Colorado store RV outdoors in colder temps probably as low as -10f - usually I keep panels on maintaining battery charge....
I get all the wiring past charge controller etc but I am perplexed as to the best approach to wire up and fuse the panels in series or parallel that will best service our needs.
Main questions I have:
1) What would be the best wiring layout for the panels - originally I thought 6 in parallel would be best but after reviewing fuse posts I became aware it maybe 2s3p or 3s2p similar layout ? Some posts I read indicate I may overload the charge controller with a 6p config?
2) What fuses/breakers to use, I'm a bit confused about this also?
3) When laying out a series of panels should I do nearby ones linked that are likely to also be shaded together or kind of spread the series out randomly so only parts are shaded? Trying to understand layout strategy....
Thanks for helping with my newbie questions.
Mike
Mike
