I've had 3 incidents of almost completely full batteries draining sometime at 9-12 o'clock at night.
Twice when I had a Tesla 120v slow charge going, once when I had my small ceramic kiln on.
I woke up to drained batteries, until the point the batteries turned off all lights.
I'm looking for guidance on diagnosis steps.
System designed using Will's 48V system as a template.
* 8 BlueSun 455W Bifacial Solar Panels, plan to add 28 more panels once my structure is up.
* 2 EG4 6500-EX Inverters
* 3 Racks, 6+6+4 48v EG4 Batteries
* 240 volt panel.
Current thoughts on further diagnosis:
* As it seems to be occurring at night only, this may be correlated with battery DC=>AC conversion draw rather than PV DC=>AC conversion, but that's just a guess.
* I could add shunts to various locations to track volt/amp when the next event happens.
* I could setup the inverter monitoring app to see what's happening when the next event happens to get better insight into what's happening.
* I could check all electrical connections just in case there's some connection issue.
Any info on why this might be happening or guidance as to how to diagnose this would be much appreciated.
* 240 volt panel.
