William,
I have seen a couple of your videos, very nice. I am a Ham Radio Operator and have several interests in terms of off-grid power and battery power.
Your links (on your youtube video notes) for purchasing the valence "green batteries" did not work. Any idea where I can get one or two and at a good price ($150 is your suggestion)?
You showed a device to demonstrate and test the charging capability of the batteries, can you mention the model number and where you obtained it?
This one looks similar, but does not seem to be the one you used. Do you think it is of reasonably equitable quality and capability?
You seem to be very focused on solar, but I would imagine most charging and switching systems work equally well if the input voltage is from wind power, hydro power, or solar power, no? So if someone had a hydro or wind turbine going through a rectifier and then a DC-DC converter outputting 12V, that could work as input to an MPPT also?
I have a small 6x4 utility trailer and am thinking to put some solar panels on top of it and place a battery inside to keep charged, what would you recommend? What installation issues (mounting a top the roof) must I be concerned with?
I also have a Ford Police Interceptor Utility that I am contemplating to add a second battery in, have you ever had any experience with West Mountain Radio products, specifically the ISOpwr+ device? I would imagine the ISOpwr+ is not compatible with the green valence batteries?
If I had a green valence batteries, what considerations must be taken into concern and what kind of device must be used to charge them from regular AC power?
If someone were going to build a system greater than 400-500W what kinds of MPPT controllers do you recommend (I am NOT building a 5-6KW system for my home), just wondering what larger MPPTs you like?
Thanks in advance and may you and your family remain healthy during these medically challenging times.
Stuart, N3GWG
![www.ebay.com](https://i.ebayimg.com/images/g/DcgAAOSw~BhbK3T0/s-l400.jpg)
Wireless Battery Monitor Meter DC 120V 300A VOLT AMP AH SOC Remaining Capacity | eBay
Capacity Range 0.001~65000.00 AH. This Wireless Battery Monitor is designed to monitor performance most kind of battery systems with capacities of up to 999 Amp hours. Trigger external Relay (Not included) when the reading reach preset value.
www.ebay.com
Stuart, N3GWG
