Hello Forum!
I started a little system with the main purpose of having energy all the time, kind of a big UPS for my office.
Buyed a little LV2424 Hybrid inverter from MPP Solar, and ended up with this:
-LV2424 Inverter
- 4 x 370Ah Trojan Batteries
- Oversized 1/0 Cables
- Marine battery switch and 200A Fuse
I was very hapy with the solution, at the moment we had a surge, the system instantly jumped to the inverter / battery supply, the computers and other equipment didnt even notice. Howemever, i found later after some trials that the batteries were our weak link:, they didn't last enough!
With 370AH at 24V, we have 8880W, being 4440W the 50% usable. My test was made with a load of 150W, they only lasted 10 - 12 hours, when according to my numbers they should last 25 - 30 hours with this kind of load. So not even half the rated capacity. Maybe i had a defective cell or something like that, but honestly i didnt had time to troubleshoot and play with them, so i better return them to the distributor. Also, with the experience learned that lead / acid could be a pain in the *** for my situation:
- You need to baby them a lot, any excess discharge / charge can damage them permanently
- Need to fill them with distilled water periodically
- They stink the place while charging (Probably the hydrogen?) - Need good ventilation for this same reason.
- Found a guy with problems with my same batteries:
So a lot of care for little usable power, i was done with them. Good thing i could get my 1500 USD back.
Was considering upgrading to AGM batteries, but they are expensive and have their good share of disadvantages too, lithium came to mind but i found the price out of my budget. (Only checked Simplify and other expensive brands).
Somehow i found William's channel and devoured the contend in a couple of days. I found a solution wich is safe, performant and the best, with a price that i can afford, LIFEPO4.
Im currently planning on implementing a 200AH or 280AH battery at 24v, so i will get a much better system without selling the kidneys, after some numbers the DIY lifepo4 should cost around 1600 - 2000USD, not that bad!. I still have some questions about this, but its better that i posted them separately as this post is long enough as it is....
So i guess i just wanted to write about my experience and show my grattitude to this comunity and William, just letting you know that this content can be a lifesaver for people like me that cant pay what contractors and companies ask for a system like this.
