Hi all - newbie here hoping to get some advice.
I've had solar done before at my last house (in a residential neighborhood) but this time I am looking to DIY. Not only for my own knowledge, but because in my particular atypical situation I can't find a vendor that isn't going to charge me and astronomical amount of money to install a system.
Before we get into requirements, I'll describe my new property and why it poses some problems most people don't have (though I imagine on this forum there are a lot who are in a similar situation). I live on a decently sized rural property. My meter is on the electrical pole, along with a main breaker panel. This breaker panel is not the main breaker for the house - it has a few breakers on it that power my 230v 1HP well pump and 110v chlorinator. The main breaker on the pole also feeds the main breaker in the house, which is about 200 feet in another direction, not near the well.
My requirements are::
- Produce >= 100% of my needs during peak usage (around 40-50kW a day) and sell back to the grid
- Have enough battery backup to keep critical systems online during a multi-day outage (well pump, refrigerator, freezer at night, possibly AC during the day in the summer)
So far I have been working with shopsolarkits.com to get a custom kit built, though I did most of the research myself first. Roughly this is what the system I designed looks like:
- Sol-Ark 15k inverter
- 24x 380w mono PVs
- 4x 100Ah 48v Jakiper server rack batteries
Now given how far apart everything is, neither I nor the vendors I looked at had any solutions for doing a subpanel that holds the breakers for all of the critical loads that wasn't going to be a nightmare and require lots of new cable/trenching. So after reading through the SolArk documentation, it seemed like AC Coupled was the way to go for my situation, as it would allow my inverter to simply provide a micro grid of sorts to my entire home and well. My plan is to build a structure near the electrical pole (my utility provider requires that I have a fused disconnect switch installed 6-10' from the pole anyway) to house all of the equipment, also near where I am going to ground mount the panels. I am going to wire everything up and have an electrician do the hookup to the meter.
But there are a few potential issues that I wanted to get some feedback from someone more experienced in this area:
1. The rep from shopsolarkits said it would be better if I did a subpanel because I could potentially overload the inverter if the grid went down and I had a bunch of load on it. Looking at the specs for the Sol Ark 15k (which can provide 12kW continuous from the batteries), and given that my peak continuous usage is around 9-10kW from the data I have, I didn't see this as a huge risk. Also I didn't read in the inverter documentation anything about this being a risk, it seems to be a fault condition but it didn't say anything about damage.
2. In the Sol-Ark documentation, it mentions requiring a subpanel if you have AFCIs (which I do in my home), but it doesn't say why from what I can tell. If that really is the case then I am going to need to either do a subpanel anyway or replace all of my AFCIs with regular breakers (which I had been thinking about anyway given how annoying those things are, constantly tripping).
Looking forward to hearing some thoughts on this!
- 24x 380w mono PVs
