Looking for some input on this.
I will have a 10KW 24v bank so obviously the natural choice would be to use a 24vdc A/C. I'm just a bit confused on what will happen on shore power and make sure I'm not missing anything here.
-On shore power with DC air conditioner, I assume the multiplus will basically be acting as a huge voltage converter and charging the batteries plus providing enough amps to run the DC air conditioner. I believe this is all happening on the same circuit, so the current going into the batteries may be a little bouncy during this as when the Air conditioner is going between duty cycles. Just checking this isn't super bad or anything, I know the current into batteries is supposed to be steady if possible. I'm guessing this also will generate a bit of heat from the charger, so the fan might spin up or whatnot.
-On shore power with the AC air conditioner, I assume this would put the inverter in some kind of "pass thru" mode 120VAC while also charging the batteries on the dc circuit. Is the inverter on, but in "standby" during this? Any guess if the multiplus would be less/more noisy than the above scenario?
-Off grid: This one is easy, obviously DC is superior as the multiplus doesn't have to do anything and can actually be turned off.
