Diddsy04
I have a 500Ah LFP battery in the canopy of my 4wd. I am using a JK-B2A8s20p BMS. I have a Victron 12/3000/120 Multiplus. I connect the 230v ac to my caravan. I have tried to run my air conditioner in my caravan and the Short Circuit Protection kicks in and shuts down the BMS. I changed the delay from 1500us to 5000us and the air conditioner will run. ( I have changed it back to 1500us). I have seen the startup I as high as 424 amps for a very short time. The maximum discharge I for the BMS is 350A. My air conditioner is an Air Command Heron 2.2 split system.
Will I blow up the BMS if I permanently change the setting to 5000us?
Is there any way of solving this problem without putting another 500Ah battery in parallel , e.g. super capacitors?
