AC200MAX DC outputs in parallel to bus bar?
elauk
Anybody tried tying their DC outputs together for an all-in-one system (like AC200MAX) to enable higher load current (>30A)? Is this crazy?
I'm curious if there are multiple regulated DC outputs that are separately fused, or a single regulated output that is split and fused based on output connector rating. If it were the latter maybe not a crazy idea to tie the the outputs together.
Thoughts??? Thanks!
Reading the manual , the dc outputs have overload protection , ie they are turned off if 400 W is drawn , this means that the units don’t suit being paralleled as unit will arbitrarily shut down and that cascades to force all parallel units to shutdown
