BabyRaccoon
- Aug 15, 2021
- 1
Hi i'm using 8s 200AH Lishen Lifepo4 cells and i have top balanced all the cells. I set the bulk charging limit to 27.4 V and float charging voltage to 27V. While charging the cells , when the cell voltage reaches to 3.42V the deviation voltage between the cells began to rise rapidly,at a point it reaches to 320mv. Even though the bms (Daly Smart BMS) start to balance the cells, the deviation keeps on going high so i stopped the charging. what is the acceptable voltage deviation between the cells while charging ?
