Hi,
First time poster so go easy please.
I have a simple Van based Solar system with Renogy parts. DCC50S charger, 2kw inverter and a pair of 100W Renogy Panels I've turned into a suitcase style setup with a home made hinges and stand wired in parallel due to max input voltage of DCC50S. Plus 2 50ah Lithium batteries.
We went away for a long weekend and found our system to be a little less than ideal.
The things it mostly powers is
Low watt induction hob(800W)
small Kettle(850W)
Halfrods Fridge cool box(55W Claimed on 240V).
USB outlet for phones etc.
A single 12v LED strip light thats a few Watts I think but barely got switched on.
Obviously the fridge is on all the time and the hob is used once for dinner mainly pasta type food so not used for ages.
I was finding the batteries were not substantial enough to do what I thought was a relatively small amount of use and after the first evening of cooking and boiling the kettle once I resorted to the backup portable gas stove. I'm assuming as much as the Hob and Kettle are big power users the fridge is the issue. We were waking up in the morning to it all being off as the batteries were dead. I was moving the Solar around throughout the day to try and maximise the Watts but once it clouded over a bit I was getting maybe 80W with peaks around 180W.
I was thinking beyond having to leave the Van Idling for a while each day to top it up my options are more solar or more Batteries.
I dont believe the battery bank ever really fully recovered from the first use of the kettle and hob.
If I add more Solar I have the option of 1 panel on the van roof(roof top tent so limited space) which would give another 100W potentially and budget would maybe stretch to a 3rd 50Ah battery.
If I add the 3rd panel it would be paralleled with the first 2 but I would have to wire it direct to the DCC50S and not with the other 2 panels. Would that be an issue?
Extra battery is easy enough as I just add it to the Bank in parallel so I know thats not too much of an issue.
Thoughts?
Youre answers/help is appreciated in advance
small Kettle(850W)
Thoughts?
