efficientPV
Solar Wizard
- Sep 24, 2019
- 1,764
If I can add freeze protection to my (6) Lossigy 12V/200A for a couple hours labor and a few dollars, why would I not do it?
I may or may not understand the issues above. My perception is that the overheat protection may or may not completely disconnect the battery from charge and discharge (depending on the BMS). If, as I suspect, most BMSs completely disconnect the negative connection from the battery to the BMS, losing power would be preferable to instantly ruining batteries. That is my untested hypothesis today.As long as you understand the issues noted above.
Of course if you are talking about using a heater, then yes, that is a much better option.
This is a valuable conversation. Thank you for your input. As I am off-grid for the last 3 years in the Mohave, it is VERY rare that temps dip below 25F in winter. That is short lived daily, and is (so far) negated by the heat my batteries create by being used through the night. I don't relish the idea of cutting my batteries up to test my BMS, but it may be a necessary evil...Not necessarily. My BMS (with low temp cutoff) only disconnects...
I read the rules regarding posting comments on this forum and I found nothing granting one member the authority to prohibit another from posting until he/she can answer certain questions.Yes, but you obviously don't know how a BMS or LIfepo4 batteries work.
Here is a quiz for you.
1. Does every BMS's high temp sensor cut off charging when tripped?
2. Does every BMS's high temp sensor cut off discharge when tripped?
3. Is it desirable to cut off discharge at low temps?
Come back when you can answer those.
Without having analyzed every BMS on the market, I believe answering NO to your first two questions is a safe bet.
I can’t answer your third question with a simple yes or no.
This post is not meant to question your or anyone else’s intelligence, so forgive me if it does.This is a valuable conversation. Thank you for your input. As I am off-grid for the last 3 years in the Mohave, it is VERY rare that temps dip below 25F in winter. That is short lived daily, and is (so far) negated by the heat my batteries create by being used through the night. I don't relish the idea of cutting my batteries up to test my BMS, but it may be a necessary evil...
My particular battery has been review by Lithium Solar(YT) and Will Prowse. During teardown, both commented on the lack of freeze protection. I believe it was mentioned that the overheat protection was a simple thermal switch rather than a thermistor. If so, it would seem to be a simple matter of installing a switch that opens at 32F in series with the existing overheat switch.This post is not meant to question your or anyone else’s intelligence, so forgive me if it does.
It is simply in the interest of safety.
Very few manufacturers specify the specific component they use in their sensors.
I just tested a temperature sensor for an EPEVER charge controller. I was surprised to learn that they use a 50 K thermistor. Most HVAC equipment I’ve dealt with use in the 5 to 10 k range. You will need to know the nominal value of the sensor in the battery in order to calculate the necessary parallels resistance.
Make sure you test the resistance at or around 77 degrees Fahrenheit. Most NTC’s have very similar operating curves so using any characteristic curve/chart you find online should get you well into the ball park.
You can add a small rheostat in series to fine tune the resistance of the parallel resistor. Place the temp sensor and added freeze protect thermo into ice water and tune to shut off plus a little margin for error.
Other than the 41F switching, I like this.McKravitts- I designed the very circuit you're describing.
I am using a Tracer 2210AM charge controller which comes with a high temp cutoff but no low temp cutoff. The native thermistor for my device is a 47k ntc and I've bought a $5 thermal switch to pull an 8k resistor into the circuit. If you look up the details on your charge controller you can easily tweak this logic for your hardware/purposes.
Note that because of the huge deadband on the switch I chose this basically locks the system out when there is a chance of damage.
I'm still working on the tweaks but I intend to overcome this lockout condition with a 5W dedicated solar panel driving a 5w heater under the battery with no other logic/thermostats involved. That should both make lockouts less frequent and will provide a means to unlatch themselves faster than waiting for a warm day.
Good luck!
You can get a 0° switch but these are generally fairly cheap devices so you'd have to test every one.Other than the 41F switching, I like this.
Shutting down the charging source is always a better option, especially if you have multiple batteries. Plus it does not inhibit using the batteries (unless perhaps it is an all-in-one unit that totally shuts down). Using one of those digital thermostats IMO is better than a mechanical "disc" since you can set the deadband as necessary, and they are quite accurate.. Could always use a disc as a failsafe.
I use six of these in various projects.
Hey McKravitts,Leeds,
That's exactly the circuit I was alluding to.
Nice diagram.
Snap disc and pop switches do have very large dead bands.
If your just switching based on barttery compartment temp or a probe attached to a battery case, there are some very inexpensive chinese thermostats on amazon. RioRand for one.
They claim to have Hysteresis Setting Range as low as .1 C
I've never used one but they are cheap.
Thanks for saving me the trouble of drawing a diagram. Ther are a few members of this forum who still don't understand what I was trying to convey. I'm not disparaging anyone. My communication skills are not great.
Hey McKravitts,
I just found this thread and I understood exactly what you were saying, the first time I read it. So your communication skills seem fine to me.
Has anyone come up with any better solutions? The cheap smart thermostats look appealing to interrupt the charge circuit only. Right now a 100 ah battery without charging freeze protection can be had off Amazon for $167. A battery with freeze protection is at least $20 more and that freeze protection is questionable. Like they mentioned it in some comment on Amazon, but when you get the battery it is never mentioned in the manual.Time to stick the battery in the freezer to see if it really works? I guess so! Honey, I need to empty a shelf in the freezer for a few hours....
....Wife's reaction!
