I bought this 12Volt system with a wind turbine on amazon and the 3 solar panels seem to work great. Wind turbine, not so much.
I have a question on adding a 1000w 24V wind turbine. It came with a charge controller from Home Depot. The charge controller also accepts solar panels so I bought another 100W panel to hook up in series for 24volt. Also bought a new 24volt inverter. 3000W. I think my new max batteries are toast. They are showing 11.7volts on my tester. So I bought 9 nissan leaf batteries 8volts each to make 3-24 volt batteries.
My questions are.. 1. Do I need to put fuses on all the positive wires? Also what is the formula to figure what size fuses I need.
2. Could I get another charge controller just for the solar array and hook both the wind turbine controller and the solar controller to the batteries? As long as everything is 24Volt?
Any help would be very appreciated.
Thanks!
Thanks!
