Good morning!
I have two 6000xp, 8 eg4-LL 48v batteries, and two panel arrays. The panels are only 4kw total, but voltage exceeds MPPT input, so it’s split.
I had planned to put both arrays on the two MPPT on the master inverter, and same with batteries.
Does it make more sense to divide equally between inverters?
If so, will the power coming from the panels aggregate and charge both battery banks equally? Will both battery banks feed both inverters equally?
Which is a better way of doing this?
Thank you!
Thank you!
