Evian_domino
Hi All,
This is my first post so go easy on me! I decided in early 2022 to add solar to the roof of my business. I went with a company who I wont name at the moment and its been a bit of a nightmare. Despite paying a considerable amount of money we didn't get anything done until April 2023. The original plan was for 40kw system with no battery. That then evolved into a 50kw system with battery back up. After many excuses on supply we finally had 20kw of panels installed. However I was told that inverters were an issue so a 10kw Solis 5g inverter was installed. Its all working but despite many calls we just get ignored. So legal route it is.
Thats the history but now I want to get the system up and running as it should be. I have done a lot of homework but want to check what what I think is a good set up works.
One point to make here is that I have a very experienced electrician available to do this work. He doesn't have a lot of solar experience but I am confident he can do the work required. We also worked initially with the contractors to route cable and fit the panels to that we can do again.
The system:
48 x Longi LR5-54HIH-410M panels
1 x Solis 10kw Inverter 3 phase connected to the grid
We also have the wiring in place to fit a further two inverters that were going to be hybrid.
The plan I am thinking of:
3 x S6-EH3P10K-H-EU Hybrid inverters connected to 3 x Pylonforce H2 HV batteries (size to be determined)
Enough additional panels to get to 39kw (based on 10kw x 130% x 3)
I now that at the moment this inverter doesn't seem to be available in the UK. However my business travels to Europe regularly and picking some up is not an issue.
The questions I have are:
1. Does this seem like a sensible solution?
2. Given the panels we have now do I do the same again? Or is there better value for money?
3. What is the best route to sizing the batteries for the system?
4. Does any one have any reasons why this would not be the best setup?
Thank you in advance for any comments or advice on this.
Regards,
AK.
The system:
Regards,
AK.
