Almost equal 12v panels
frankz66
Aci Sant'Antonio Catania
Hello everyone, being inexperienced I wanted to ask:
I have a string in series of 4 12v monocrystalline panels with the following characteristics :
Technical Data] Rated Power (Pmax): 180W -- Max Voltage (Vmp): 19.10V -- Max Current (Imp): 9.43V Current (Imp): 9.43A -- Open Circuit Voltage (Voc): 23.20V -- Short Circuit Current (Isc): 9.99A -- Max System Voltage: 1000VDC System Voltage: 1000VDC --
I have seen on offer of 170watt panels so 10 watts less with the features attached in the photo.
If I wanted to mass-proize these other two 170-watt panels being the VOC tolerance and ampere do I do well or do I buy two other identical 180-watt panels?
I agree they should work pretty well. All you have to look for in series is the amps. Volts are added so amps are the key.
I've seen quite a few systems with various panels.
My rule of thumb is if Voc is within 10% (and that changes A LITTLE) with age.
Then you're good.
I saw a Voc different of about 20 to 30% and it caused an inefficiency (loss) about 25%.
This one parallel sets at a different Voc - it wasn't mix and matched in series.
Series should have a greater effect.
