new to all of this, but trying to balance some new eve 280 ah cells (8s), while in series...(i just don't want to disassemble everything to put them in parallel since they are built into a compression jig in an awkward box...). the JBD bms is trying to balance things above 3.4v but one cell is higher than the rest. i tried charging the lowest cell individually (while still wired in series) up to the median with a small benchtop charger which worked well. but how to bring down the highest? bridge that cell with a resister individually? how big a resistor? 3.2v, 280 ah cell, it's at 3.45v, everything else is at 3.375. or run a small device off it??? what runs on 3.5 v? flashlight bulb? i'll try letting the bms finish the job once i get everything more or less close together. or will i just be chasing my tail once everything gets a bit higher? thanks for help/suggestions
