Just make sure you size your thickness and width correctly, and ensure there is no oxidation on the mating surface. Should be fine.
Right said Fred.Aluminum isn't a poor conductor. Stainless is a poor conductor. Aluminum is roughly 60% what copper is in conductivity. He's not threading the bus bar, so thats moot, and atleast the bus bar material will match what the terminal will be made of, which will prevent galvanic corrosion. As long as he preps the bus bars correctly and then hooks the battery up, he should have no problem.
The aluminium plates that I have are literally identical in thickness and width as the bus bars that came with the battery.
The person who built this house had aluminum wires ran underground to my barn..
I pulled that out and put in copper. 30+ years had taken its toll on the aluminum wire, some places looked really bad.
After that I'd never go/use aluminum for wiring/plates...
2mm x 12mm
Scale and weight are power co factors, as well as cost.What are power lines made of
