It's nice to see you find the hired professional tightened mess up
I notice you have new service entrance wire, disconnect and new wire to your meter + added ground wire.
View attachment 229344View attachment 229345
Definitely looks like $ pro quality work $
I hope it wasn't too hard on your wallet chuckles
Actually it was free luckily, it's part of the grid policy in the UK to provide power to your house that is sufficient, but the whole thing sucks in my opinion.
For instance they have only upgraded my main fuse because I'm having a electric vehicle home charger installed at my home which runs at 7.5 kilowatts per hour maximum.
As I'm on a loop supply i just have 60 amp main fuse rating. In order for my electric vehicle company to install the charger they have to get proof approval off the grid supply to cover themselves in case of issues further down the line.
It is only then when they see a request form that they check any property that has wiring that could be 20 30 40 50 years old.
For instance when the grid came to my house a couple of days ago, to change the fuse, he said I'm very surprised that you have not blown this fuse or caused the very thin wire that was already in to burnout when I was running a 10.5 kilowatt shower electric at the same time as other devices.
Which I haven't used for quite some time anyway.
But the point is the house was wired up for a 10 kilowatt shower and that's how the job was before the upgrade with the very skinny wire coming in from the loop, from my next door neighbour
Which makes no sense because I'm now adding a 7.5 kilowatt device and they've kept the main fuse at the same rating but modernised it.
They said I can request 100 amp fuse which would mean taking me off a loop supply and putting a wire straight through to the main's wire that comes down our street instead of being connected to a loop supply.
Which again sucks because these sort of things they should be doing anyway for every house so because a 60 amps main fuse is pretty limited, because I would also be pretty limited as to what I could charge high voltage batteries at, if I'm running quite a few appliances at that time.
