Hi.
I am a little uncertain how the BMS operate.
Currently my scenario is with deep cycle
So I have a charge controller that can output 60A
With a shunt my charge controller is set to charge at 40A.. but if battery has a 20A load.. the battery can still have a 40A charge. And 60A is flowing from the charge controller
I know Lifepo4 can charge quickly vs deepcycles
I understand for example a 80A output Lifepo4 BMS has 40A charge rate. How does that compare to my above scenario?
I am confused about the way a BMS works
I have a load of 20A the BMS has a 40A charge rating
Does this mean if my charge controller can charge the batteries at 20A and the other 20A is flowing through the BMS to the load on the batteries?
Regards
Regards
