I am probably showing my ignorance here but this bothers me so I’ll chance it. System: growatt 3000 spf, overkill bms, 24v lifepo 8s, 9000watt backup genset.
The generator has a 30 amp outlet. I have the growatt set max charge to 50 amps which it shows on the display when the generator is running and the bms shows the current as 75-80 amps. What gives? Can I be getting 80 amps from a 30 amp outlet? Or do they all measure current in different ways? I only run the generator when there is no solar so no additional amperage there.
