Hi All,
Last winter my solar system stopped working, system simply stopped--no lights, no noise on inverter. I had too many other projects, plus work travel, etc. so I didn't try to troubleshoot then. But yesterday I finally had a look the system:
2 x 24V Ampere Time 100Ah in series for a 48 volt system
I currently have no load on the system.
In the morning the system was not running at all. I measured the voltages on the batteries--same as before:
Last fall I had a similar issue, but after recharging with the solar panel, everything seemed to be working.
I know there are ways to correct bad cells if you have access to the individual cells, but is there anything that can be done with the Ampere Time battery, which is sealed?
Last winter is was < 32F outside, but I don't think my garage (where the system is stored) got below freezing,(but I'm not positive about that).
System = Growatt SPF 3000TL LVM-ES (not connected to line power, only to solar array and batteries)
2 x Ampere Time 24V 100 Ah
6-panel array give 198 input voltage (no load)
Thanks!
Ron
- 1 battery measures 24V
- 2nd battery measures 8 volts
Thanks!
Ron
