drracing07
- Dec 9, 2022
- 15
found another 15a charger with a display and it's pulling in 14.5a
Thanks! I was searching youtube for reviews but none were the heated version. I must have missed this one.Sounds similar to what Lithium Solar reported in his Youtube review of the 200 ah version.
OK so next question, what would be a good battery in place of this? I'm just worried about this same thing happening again. Cold weather, western PA but I have the batteries in an insulated box. Seems like SOK is one of the better options. To the regular, non-heated Ampere Time batteries do this, from anyone's experience?Yup, just watched it and that's EXACTLY what's happening. I guess we'll see what they get back with.
I just pulled the batteries back from the site to isolate and troubleshoot. I made a video to better show whats going on.
12/09/2022 | Synology Photos
photos.pinecone.fun
I'm using a 13.6v power supply with those clamps. Both batteries are doing the same thing.
photos.pinecone.fun
It may have been, but I tested again after warming back up and it did the same thing. Ampere time got back to me with a sassy comment about not doing what they are asking to troubleshoot when I brought up that last vid. Waiting on a variable DC supply now to complete testing, but ordered a SOK battery so i can get the site back up.We'll, question: Was the battery 32F or under when you tried to charge in this video?
I think this issue the OP is having is the same issue that is shown in this youtube review of this battery that was highlighted above in post #23. I linked directly to the part where he describes the issue. The BMS disconnects the battery for a second whenever the charging current turns off. So yeah, I wouldn't buy one of these.Could be possible the battery is drained, and entered low cell protection. Then you're trying to charge it, but it's too cold, so it's using the charge power to run the heater.
Have you left it on the charger for hour, or over? Seems like and hour should be long enough for the heaters to warm it back up, if the ambient temp allows.
I noticed Enjoybot has the new Plus version with low temperature protection advertised as a feature. Has anyone truly verified this? Remember when Will first reviewed them, they also had said they had low temp protection, but it wasn't true.If you're looking for a cheap battery, Enjoybot now has a version with low-temperature protection. I have no experience with them, though. It's one I'm considering for my upgrade since support for the Weize batteries seem to be an issue.
Based on others' experience, SOK batteries are very good and now include bluetooth as well as versions that are heated if you really need the heated version. The 100ah heated version is not much more than the regular 100ah, but the 206ah is much more expensive than it's unheated counterpart.
I recently bought their 300AH version and I just discovered a serious problem with their BMS configuration. They claim that the BMS will shutoff charging at 0C (32F) while discharging is possible up to -20C, but read on.I noticed Enjoybot has the new Plus version with low temperature protection advertised as a feature. Has anyone truly verified this? Remember when Will first reviewed them, they also had said they had low temp protection, but it wasn't true.
