Hi
I was wondering if there was any consensus on max charging amps for a parallel first string such as a 4p16s of 280ah 3.2? Max current on an individual cell is 1c which would imply 4c for 4 parallel cells. Realistically that's into arc welding territory, but I'm thinking about additional solar arrays in order to reduce time to charge. Any real world experience? Any one using a high amp BMS?
EVE specs say standard charge time is 2 hr is 0.5c. IIRC, you normally size arrays with FLA so that the array can charge the FLA al least in 1 typical day and ideally in half a day. Maybe there should not be any expectation of charging a 4p16s in a day. Other than the published charge times, I have no sense of charge times on LFP. Is 0.25c rate 3 hrs?
thx
thx
