I'd like to set up my Delta pro to only charge from solar panels and connect to critical house circuits via an ATS. The
MOES Dual Power Controller 50A 5500 Watt Automatic Transfer Switch for Off Grid Solar Wind System ATS DC 12V 24V 48V AC 110V 220V.
Seems like a good option to utilize the DP during peak solar, the MOES ATF can be set to switch to AC when the DP reaches a preset battery discharge level and switch back from AC to the DP when battery reaches a preset level of charge. Seems perfect to my relatively inexperienced eye, but there appears to be one possible problem. The ATS requires a battery connection from the DP in order to function. Does anyone have any thoughts how to accomplish this? Thank you.
