Been trying to get my BMS activated for hours now without success. I really hope someone here can help me out!
I have a 4s 250A common port Daly smart bms that has been working great for two years in my camper van. Whenever it shut down I could reactivate with charging. Now I decided to disassemble the package and top balance the cells since one cell started drifting off a bit. After top balancing and putting it all together I can't get the BMS to wake up. I guess it kind of makes sense since that it doesn't respond to charging since the battery is already 14.5V with all the cells fully charged. Also tried connecting p- and b- ans turning on the charger. I've been going through the forum and YouTube videos to figure out how to activate with the 2 pin switch method. I don't have the light board switch. The solutions I have found is to connect the two pins for ground and switch. In most cases it seems to be pin 1 and 3 on the 8 pin connector to the light board switch. My BMS does not have this connector slot. Any ideas on what to do?
Attached pictures of the BMS and the available slots and pins. Apart from the balance cables, NTC and UART there is an unmarked 5 pin slot on the front and on the back a 3 pin marked monitor, an unmarked 2 pin and an unmarked 6 pin slot.
Any help greatly appreciated! I need to be on the road tomorrow.
