Hi.
I have a cabin with a 24v 12kw li-ion battery setup. 230v/3000w inverter.
Its installed a heating cable in the insulated batterybox that is controlled by a 230v temp thermostat. In wintertime, when i arrive at the cabin , i turn on the inverter, the heating cables heats the batteries to +10°c.
After a day or so I charge with the generator if needed. Then i dont charge freezing cold batteries..
Works fine.
But here's my idea;
What if .. i set up a single solarpanel connected to a some sort of 12v(?) heating element in the batterybox. Need a thermostat set to +10 or 15°c. Then all year round this panel will feed the heating element to set the battery to 15°c, when the fall comes with colder weather its still sun to heat the battery, and in december and january it might not be much sun but the whoke battery mass is warm so it will keep itself warm for a long time. Maybe, then when i arrive in december in like -15°c , it will need less heating from my 230v heater before i run the generator.
What do you think? Will it work? Worth the effort?
Can a heating element work without a charge controller? Like a 250w panel running a 100w heating element? With weak sun, just a litle heat, good sun warm heat..
The thermostat can be powered from the main battery, just the relay connected to the heating.
Works fine.
But here's my idea;
